Work whitout internet conection.
Hi.
I have a query regarding working with autocad 2021 without an internet connection.
When executing the program, an annoying window appears that I would like not to show (see atach).
The computer is connected to the internet at the time of activation, but sometimes I have to go to workplaces where I don't have an internet connection.
Thank you.
imadHabash
you can follow this AKN solution , hope it's help . >> Click <<
Imad Habash
It is really annoying to close the window every time I start autocad offline.
Thanks, but it doesn't fix the error.
Grover_Puma
I found something around here maybe it can help you
https://forums.autodesk.com/t5/autocad-forum/turn-off-constant-internet-access/m-p/3240008
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
Pointdump
Ismapm,
"...sometimes I have to go to workplaces where I don't have an internet connection."
Use your phone as a hot spot. I've done this quite a bit with both bluetooth and USB cable.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
In my work I use different software companies. Only autocad shows me this annoying screen.
Closing the window is less annoying than activating the data connection on my phone.
My question is about some customization option that allows disabling annoying messages.
Thanks for the suggestion.
