Move defaults to displacement
Message 1 of 11
I have been using AutoCad for more than a few years.  I recently upgraded to AutoCad 2020.  When I use  the move, copy, rotate, or stretch command I the past I could specify the base point.  Withe 2020 These commands default to the displacement, which just executes the command to whatever point it want to.  How do I disable the displacement option.  I tried pinning the command line, setting the Dyn mode to 0, but nothing stop the commands from defaulting to displacement.
Replies (10)
Message 2 of 11
imadHabash
you must have    Specify base point or [Displacement] <Displacement>:    in your command line after selecting the object , have you? i think that you have press enter twice to get the way that you have .
Imad Habash
Message 3 of 11
vinodkl
Can you check if your AutoCAD is updated?
And also after executing the command press F2 and then copy the command history and post in the reply.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 4 of 11
I downloaded the latest update. This worked for several command, but the move command defaulted to displacement.
Command: _move
Select objects: 1 found
Select objects:
Specify base point or [Displacement] :
Specify displacement <0.0000, 0.0000, 0.0000>:
Command: *Cancel*
Message 5 of 11
ВeekeeCZ
Try to type
.move
(with an initial dot)
and see...
Message 6 of 11
when it asks you to specify base point or displacement, you need to pick a point. If you just hit enter it will take you to the displacement option.
Message 7 of 11
OK after many years of hitting enter for the base point I'll need to learn not to do that.
Message 8 of 11
I can't get that far.  When I right click to enter after select object the AutoCad  just defaults to displacement and moves the object.
Message 9 of 11
imadHabash
instead of right click and you just press keyboard enter or spacebar , any changes ? OR / and if you change your mouse with another new one , any changes ?
Imad Habash
Message 10 of 11
Using enter on the keyboard seems to work. I will try a different mouse.
Message 11 of 11
dumi_mihai_i
Community Visitor
Community Visitor
It is not ok to do additional clicks!
How come it works flawless from command bar but you need to press an additional Enter/Space when using keyboard? (in command line, there are no difference in commands, excepting the auto displacement when using keys)
