AutoCAD Forum
Windows 10 compatibility
56 REPLIES 56
Message 1 of 57
92160 Views, 56 Replies
Will Autocad 2014 be compatible with windows 10?
56 REPLIES 56
Message 41 of 57
I agree with your answer.
I went up to Windows 10 on my laptop because I do not work in this, if not another machine, I tried AutoCAD 2015 and go slow, I modified on AutoCAD everything possible to fence quicker.
Until now I could not do it. Surely when Windows 10 be official Autodesk take out patches, but in the meantime keep trying.
PS: it was it clear that "not recommended upgrading to Windows 10 if you use your machine for work." No more copying and pasting and more contributions
Thank!!!!!
Thank!!!!!
Message 42 of 57
Well, I just checked the Windows 10 support link again for updates and found this: "The 2013–2014 versions of AutoCAD products will not be supported on Windows 10." That's disappointing as the last time that I checked, I got the impression that they were going to try to support from 2013 forward. Since I bought 2014 and am not subscription based and do not have a pending project, I guess it's time to upgrade and see what happens. Hopefully, since I already have it installed on 8.1, I'll only have minor issues with the online help like were described earlier. Any last minute advice before I push the button? 🙂
Message 43 of 57
Download a copy of Macrium Reflect Free and make an image of your hard drive onto an external drive. It's really easy to do (there are YouTube videos if you search) and it works flawlessly if you have to reset back to 8.1. Windows 10 does have the ability to roll back built into it, but Macrium is just another piece of insurance and it works perfect (I've done it a few times).
Message 44 of 57
pendean
pendean
Community Legend
Community Legend
If needed, you can buy this to get older AutoCAD versions to run in Win10 http://www.longbowsoftware.com (I'm not affiliated with it at all, just see it being recommended by others stuck with older software and Win10).
Message 45 of 57
Autodesk pretty much cuts off all prior years with every new release. The fact is that many have autocad working on Windows 10.
I took a machine running Vista 32 bit and AutoCad 2007. I did a custom install of Windows 7 Pro 64 bit in place. Then I used PCmover to move all my programs that were on Vista to the new install. I then let Windows 7 Pro get all it's updates from Microsoft (around 224 updates). After that I did the free upgrade to Windows 10 Pro 64 bit and Autocad 2007 runs fine on that machine. I did not have to reinstall or nothing. It runs without a hitch.
Tags (1)
Message 46 of 57
JOHNLLOYD7213
JOHNLLOYD7213
With the release of SP1, AutoCAD 2016 is now officially supported on Windos 10.
Anyone got the intestinal fortitude to do the 7/8/8.1 to 10 upgrade?
Not me. For the time being I'm sticking with 64 bit 7...
Message 47 of 57
Read my entry just prior to yours.
Message 48 of 57
pendean
in reply to: JOHNLLOYD7213
pendean
Community Legend
Community Legend
There are better things to do with your life than worry about Win17/8/8.1 vs Win10.
Get Win10 with your next great PC upgrade and the AutoCAD version that goes with it all.
Message 49 of 57
pendean
pendean
Community Legend
Community Legend
Your posting is too limited in nature to be truly and widely helpful: you simply experienced what the rest of the 99% of users upgrading to Win10 did (myself included, no issues at all). It's the 1% you can't get it to work with all the tips posted so far.
This is the AutoCAD 2013-14-15-16 forum, if you truly want to be helpful, post in the AutoCAD 2007 forum for users needing your exact fix.
BTW, the most common tip for a perfect install is to do what you did: not new, and reported heavily by others, by I totally appreciate you sharing to confirm it.
Message 50 of 57
in reply to: pendean
Well, I did it. Thank you all for your info. On initial check everything on AutoCAD 2014 works on Windows 10 from a Windows 8 upgrade, even the help menu since I was advised ahead of time and set chrome as my default browser. Maybe I was overly cautious and making much ado about nothing but it seems that since 2014 was designed for windows 8, even with out being supported, it's close enough that it works seamlessly in the new OS. I'm sure from what I've been reading that having it pre-installed on it's native OS makes the difference, I'll keep you advised if any issues pop up during production usage.
Message 51 of 57
Emmsleys
Emmsleys
To provide an update on this topic and thread. The following AutoCAD versions have also been tested with Windows 10.
• AutoCAD 2016 is supported with the application of AutoCAD 2016 SP1.
• AutoCAD LT 2016 is supported with the application of AutoCAD LT 2016 SP1.
• The 2016 version of most AutoCAD-based verticals should be installable and perform as expected on Windows 10
The English language versions of AutoCAD 2015 and AutoCAD-based verticals should be installable if you have received the Windows 10 update, KB3081448 or later.
Other AutoCAD language versions and language packs can be installed if Windows 10 update, KB3105210, is applied prior to installation.
DWG TrueView 2015 can be installed if Windows 10 update, KB3105210, is applied prior to installation.
The 2013–2014 versions of AutoCAD products will not be supported on Windows 10. For all links and further information on this topic please read over the AKN Article
Thank you for your participation. Any and all feedback and workarounds are welcomed. Smiley Happy
Happy Posting.
Sarah Emmsley
Technical Support Specialist
Happy Posting.
Sarah Emmsley
Message 52 of 57
I have tried installing my older 2016 version of Inventor on Windows 10 and it does not install. I get the same error 1402 as I do when I try to install 2018 version. Is there a fix for this problem?
Message 53 of 57
Message 54 of 57
JDMather
JDMather
@Anonymous
This thread has been marked solved - and,
You have posted in the wrong forum - the Inventor forum is over here https://forums.autodesk.com/t5/inventor-forum/bd-p/78
and the installation forum is over here  https://forums.autodesk.com/t5/installation-licensing/bd-p/24
Do you have these files?
or these files
@Anonymous
or these files
Message 55 of 57
AutoCAD 2014 LT will run on Windows 10 if you select the correct Compatibility mode.
To set this mode:
After installing AutoCAD 2014 LT,
Right click the icon for the program.
Select Properties.
Select the Compatibility tab.
Under "Compatibility mode" select Windows 8 or Windows 7
It should work now.
To set this mode:
Select Properties.
It should work now.
Message 56 of 57
Alfred.NESWADBA
Alfred.NESWADBA
Sometimes, and very much depending on which version of Windows 10 (Anniversary update, Creators update, Fall Creators update, ...) ... and the problem is not just AutoCAD start, it's sometimes the licensing service which has issues.
So from my point of view: if you are working in a professional environment and you need AutoCAD to get your daily job done DO NOT update to Windows 10 (or udpate AutoCAD). Every single update (also small updates) might break it's functionality and you can't do your work.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
Message 57 of 57
I agree.
I agree.
AutoCAD Inside the Factory
