Window size does not stick
kczerwonka
Message 1 of 9
kczerwonka
When I run Dimension Style Manager (Command line: '_dimstyle) the window that pops up is too small for me, so I drag the lower right corner diagonally to resize it to my preference. I finish and I close the window (end command). Later, in the same AutoCAD session and DWG, when I execute the Dimension Style Manager command again it has  reverted back to its previous smaller size.
This is always the case with every AutoCAD session and in every DWG that I open.
I want it to keep the larger size that I drag it to.
How can I make it keep the larger size?
Thanks.
Replies (8)
Message 2 of 9
Ed__Jobe
I tested mine and you are right. The dialog should remember your setting. Most dialogs do. I would create a support ticket and report it as a bug.
Ed
How to post your code.
Message 3 of 9
kczerwonka
How do I create a support ticket?
Thanks.
Message 4 of 9
pendean
Community Legend
Community Legend
@kczerwonka Please post a screenshot of your ABOUT command pop-up in AutoCAD and let us know what is your OS when you get a chance, and let us know what changed with your setup that this stopped working for you.
Message 5 of 9
Ed__Jobe
From your account page, https://manage.autodesk.com/home  >click on the box that says 'no open support cases'.
Ed
Message 6 of 9
kczerwonka
AutoCAD 2023 has always done this. Please see attached files.
Thanks.
Message 7 of 9
kczerwonka
Thank you. I created a support ticket.
Message 8 of 9
pendean
Community Legend
Community Legend
Thanks for the screenshots.
While you wait on support (and they are going to make you do it anyway), it appears you are missing the 2023.1.2 Update. Get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
Also go ahead and set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD too. Test your dialog box out in the interim.
Message 9 of 9
kczerwonka
I installed the update and I also changed GFXDX12 to 0 as you suggested. It did not fix it.
Thanks.
