AutoCAD Forum
Wierd X Y coordinates
4 REPLIES 4
1744 Views, 4 Replies
AutoCAD is giving me wierd coordinates in "List"  Can someone explain this to me?
    Constant width 0'-0.0000"
              area   0.0000 square in. (0.000000 square ft.)
            length   1605'-9.4183"
          at point  X=2396348'-0.1200"  Y=245925'-0.2400"  Z=0'-0.0000"
          at point  X=2.8737E+07  Y=245878'-5.6400"  Z=0'-0.0000"
4 REPLIES 4
JDMather
Exponential (scientific) notation.
X=2.8737E+07 = 28,737,000
Typical for very large or very small numbers.
What is "weird" about the y coordinate?
With such large numbers, do you really need decimal inch units (especially to 4 decimal places)?
Is there a logical need to work a long ways away from 0,0,0 (maybe you can move when finished if needed)?
in reply to: JDMather
Well, it is an old CAD file from a contractor.  It is of some fee mineral outlines in Lafourche. If you want to run it, here is a bit of the file.  I did load the scientific into Excel to compare points.  As you can see, they are points that are WAY out there.  Atttached is a screen dump of how it comes into ArcGIS and how it is in AutoCAD 3D Map (the blue outlines.)
Open
              area   486630016.5384 square in. (3379375.114850 square ft.)
            length   11345'-2.5057"
          at point  X=2.8721E+07  Y=247672'-0.2400"  Z=0'-0.0000"
          at point  X=2.8721E+07  Y=247671'-8.2800"  Z=0'-0.0000"
          at point  X=2393424'-0.1200"  Y=247665'-5.4000"  Z=0'-0.0000"
          at point  X=2393410'-1.0800"  Y=247659'-2.6400"  Z=0'-0.0000"
          at point  X=2393390'-2.7600"  Y=247648'-10.5600"  Z=0'-0.0000"
          at point  X=2393372'-6.0000"  Y=247630'-6.9600"  Z=0'-0.0000"
          at point  X=2.8720E+07  Y=247608'-3.7200"  Z=0'-0.0000"
          at point  X=2393341'-1.3200"  Y=247590'-0.3600"  Z=0'-0.0000"
          at point  X=2393331'-4.3200"  Y=247573'-10.3200"  Z=0'-0.0000"
          at point  X=2393329'-9.0000"  Y=247549'-9.9600"  Z=0'-0.0000"
          at point  X=2.8720E+07  Y=247535'-11.8800"  Z=0'-0.0000"
          at point  X=2393348'-1.2000"  Y=247530'-1.5600"  Z=0'-0.0000"
          at point  X=2393354'-3.6000"  Y=247518'-2.6400"  Z=0'-0.0000"
          at point  X=2393358'-8.2800"  Y=247494'-3.4800"  Z=0'-0.0000"
          at point  X=2393359'-0.2400"  Y=247474'-3.3600"  Z=0'-0.0000"
          at point  X=2393369'-9.7200"  Y=247426'-5.2800"  Z=0'-0.0000"
          at point  X=2.8721E+07  Y=247420'-7.6800"  Z=0'-0.0000"
          at point  X=2393394'-0.3600"  Y=247414'-10.0800"  Z=0'-0.0000"
          at point  X=2393404'-3.2400"  Y=247401'-0.1200"  Z=0'-0.0000"
          at point  X=2393412'-6.8400"  Y=247383'-1.6800"  Z=0'-0.0000"
          at point  X=2393419'-2.0400"  Y=247347'-2.7600"  Z=0'-0.0000"
          at point  X=2393423'-9.0000"  Y=247311'-3.4800"  Z=0'-0.0000"
          at point  X=2393424'-2.5200"  Y=247283'-3.4800"  Z=0'-0.0000"
          at point  X=2393430'-6.1200"  Y=247265'-4.6800"  Z=0'-0.0000"
          at point  X=2393456'-9.2400"  Y=247251'-9.8400"  Z=0'-0.0000"
Alfred.NESWADBA
as JDMATHER already told you, that is normal for such big (geographical) coordinates.
What you can do to get the list or coordinates with larger values in front of the decimal sign is to reduce the number of digits behind the decimal separator: so start command _UNITS, and for the length==>precision set the number of decimal places to less than 4 (which is your current setting).
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Alfred,
I understand the JDMATHER's explanation and I know the purpose of scientific annotation of large numbers. I was responding more to his question of working so far away from 0,0,0. It is not a matter of choice, more a georeferencing necessity.
Lynn
______________________________________________________________________
This email has been scanned by the Symantec Email Security.cloud service.
For more information please visit http://www.symanteccloud.com
AutoCAD Inside the Factory
