AutoCAD Forum
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
How do You add to Standard Scale for viewports & fields
6 REPLIES 6
4351 Views, 6 Replies
I want to use fields to note some viewports but the 3/4"=1'-0" comes up as 1:16. The properrty of the viewport also shows as 1:16. How can i modify this so it will come in as 3/4"=1'-0"? I also have some civil viewports such as 1"=10'-0" & 1"=20'-0" that i have to do as a custom viewport. Can those be adding into standard scales?
6 REPLIES 6
pendean
FIELD, OBJECT suboption, select the viewport and now instead of OK look at the far right of the pop-up and define the settings you want.
in reply to: pendean
I'm not sure what you meant there but i used custom scale & then select #"=1'-0". I think i had to do something similar to get the civil scales to work in fields. It's odd to me that 3/4"=1'-0" is not part of the standard scale with fields.
Patchy
Are you sure it doesn't have 3/4" = 1'-0"   ??
Patchy
If you want to add all preset scale based on units in, ft, metric....
Type in :   -DWGUNITS then select the unit you use, then go to scalelistedit , hit RESET
in reply to: Patchy
yes, when i do it with custom scale it reads 3/4"=1'-0"
When i use standard scale i get 1:16.
When i try to change the standard scale on the viewport properties.
It reverts back to 1:16 when i close the properties pallette.
in reply to: Patchy
It's in my scale list but it doesnt show up in standard scale when i use the field command.
Technology Administrators
