Why can't I set a layer's color to ByBlock? Both that and ByLayer are greyed out. I have an urgent need for this functionality!
Solved by SeeMSixty7. Go to Solution.
I have A LOT of blocks where certain lines are on a given layer. That layer used to be set to a certain color that wouldn't change, but now I have to make ALL THOSE LINES set to ByBlock color. Isn't that the whole point of layer control?? Do I really need to go through several thousand blocks one by one and change the lines to "ByBlock" manually???
Why is it even in the dialog box if it's not available??
Because it's a standard dialog that is also used when assigning a color to an entity. Entities can be assigned the color ByBlock, layers cannot.
yeah I was afraid of that. I colored all the blocks using several LISP routines, so I'll have to go back and modify the LISPs.
@Anonymous wrote:
Why can't I set a layer's color to ByBlock? ....
Another consideration:
Suppose you were able to assign ByBlock as the color of a Layer. If that Layer is current and you draw anything other than a Block on it [I'm not aware of any way to restrict a Layer to allow only Blocks to be drawn on it, or any other similar entity-type restrictions], what color would or should it be?
