Why burst command shrink Excel table
08:46 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So here the situation, I attached and then binded a dwg file to a template file. The attached file is a drawing converted from Solid Edge. Then, I used BURST ALL , since it came in one block, to edit the layers's drawing. In the case that the drawing contains a Excel table, the BURST command shrink the table and reposition it at the insertion point of the attached drawing. So how can I replace the table at its initial position or how can I avoid this problem?
Thank you all
