Why burst command shrink Excel table
So here the situation, I attached and then binded a dwg file to a template file. The attached file is a drawing converted from Solid Edge. Then, I used BURST ALL , since it came in one block, to edit the layers's drawing. In the case that the drawing contains a Excel table, the BURST command shrink the table and reposition it at the insertion point of the attached drawing. So how can I replace the table at its initial position or how can I avoid this problem?
Thank you all
Alfred.NESWADBA
I never got a SolidEdge file with an embedded XLS-table ... so to play with this I would need the file.
However, the main question from my side is why you use _BURST instead of _EXPLODE ... and does _EXPLODE also change the table's size?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thank you for your suggestion, Explode works better in this case, it doesn't affect the table. I used BURST because my superiors did it that way, but it does not work for that particular case.
Alfred.NESWADBA
Command _EXPLODE should be the standard to split block-insertions to it's entities.
_BURST should only be used for one specific situation: when you have block-insertions with attributes and you want to keep the attribute values as text ... just for this.
- alfred -
Alfred NESWADBA
Ok I see, thanks. Last thing, would you know why the inch symbol of all my dimensions disapear after the Explode (it did the same thing with BURST). Here my dimension type :
50
[1-1/2'']
The first dimension is in mm and the second in inch, but I lose the inch symbol after EXPLODE. I also lose the specific parameters of the inch dimension.
Alfred.NESWADBA
I would need a dwg-file to see and to test with the entities.
By default this should not happen, however as you wrote this geometry was imported from some external file formats, a lot of things can happen.
- alfred -
Alfred NESWADBA
