AutoCAD Forum
Where is the REGEN command in the Ribbon in AutoCAD 2010?
5 REPLIES 5
1450 Views, 5 Replies
In older versions, it used to be in the VIEW menu. I could not locate it in the ribbon.
5 REPLIES 5
Jonathan3891
Regen command is not accessible through the Ribbon. You may want to enable menubar using command Menubar and set the value to 1. Regen command can be accessed through view menu
Jonathan Norton
Blog | Linkedin
pendean
Yu can always put it anywhere you want to on the Ribbon: CUI command is the place to get started, just drag it from the Commands list at the bottom left to a Panel of your choice at the top left.
Abbreviation is RE I believe, way quicker than any other method to trigger.
I tried to include the regen command in the ribbon. It is not allowing. I could only insert it in the quick access toolbar. There was no icon defined for regen. So, I had to create one using the drawing tools.
pendean
The QAT would make the best location anyway, it's always there no matter what.
Okay. Thank you so much.
Technology Administrators
