Where did the "Drafting & Annotation" panel go?
I was trying to customize some tabs in the " Customize User Interface" and I accidently removed the "Home 2D-Draw" panel from the entire "CUI".  Can this be done?  How do I get it back so I can draw?
I am running AutoCad 2016
Chris
< Edited Content for better support. >
Replies (9)
natasha.l
Hello @Anonymous,
Make sure you have your Workspace set to "Drafting & Annotation", it displays the 2D toolbar menu.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Alfred.NESWADBA
you can search for that file:
C:\Users\<UserLogin>\appdata\roaming\autodesk\autocad 2016\r20.1\enu\support\acad.bak.cuix
If such a file exists then first copy the file "acad.cuix" to a safe place, then rename "acad.bak.cuix" to "acad.cuix" (please do all these steps while AutoCAD is not running), then restart AutoCAD and see if your workspace exists now.
If it does not exist you can reset the acad.cuix to default as shown in that screenshot (right-click the "ACAD" item):
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Natasha,  I did that, but thanks.  like I said, I think I removed it from the "Customize User interface" .  I just opened all the folders in the "CUI" and did not see another "Home 2D-Draw" file.  How do I git it back where it belongs so I can draw again?
@natasha.l wrote:
Hello @Anonymous,
- alfred -
Alfred, Thanks for your help!!!  I just reset the file and it worked great .  I knew I came to the right place.
Thanks again
Chris
EmanuellaB46YN
Community Visitor
Community Visitor
im missing it also. im currently on cad 2023 architecture.. is there a work around?
pendean
Community Legend
Community Legend
Are you new to that variant of AutoCAD by chance?
You need to run AutoCADARCHITECTURE "as AutoCAD" to get the AutoCAD menu and workspaces
manavrajendrabhai_patel
Community Visitor
Community Visitor
I don't have the drafting and annotation panel on my software. Can you please help me to enable that panel ?
pendean
Community Legend
Community Legend
@manavrajendrabhai_patel wrote:
I don't have the drafting and annotation panel on my software...
That does not exist, never has, as a panel in the Ribbon: do you mean "workspace"? Something else?
Share with us a screenshot of the ABOUT command pop-up inside your program please.
prokos_k
Community Visitor
Community Visitor
where do I find annotate in 2025 version
