AutoCAD Forum
When switched from 2d wireframe to any other style half my drawing disappears
7 REPLIES 7
Message 1 of 8
849 Views, 7 Replies
So my draft is basically a box with a sliding lid. Both pieces are their own 3d solids. I designed the box before the sliding lid, and now when I select any angle on the viewcube it aligns it to the lid and basically forgets about the box. I cant explode my box to edit it either. Pretty much the only way cad will recognize my box's existance is in 2d wireframe. Any help is appriciated! Thanks
7 REPLIES 7
Message 2 of 8
nestly2
Welcome to the Autodesk forums.
Can you attach the drawing here, and also clarify which version of AutoCAD you're using?
Message 3 of 8
in reply to: nestly2
Happily. And I'm on AutoCAD 2015
Message 4 of 8
nestly2
Unfortunately, I don't have any positive results with your drawing.  The first thing I noticed opening the drawing is that the UCS icon is faded and not it's normal color.
SELECT > ALL finds 4 objects which are your "Lid" and two other Solids and one Surface.  A sort of "ghost" image of them can be seen by using MOVE or SCALE command while they're still selected, but LIST command indicates that they don't have any size/shape.
I also tried to export/import as DFX without any improvement.  Did anything unusual happen (Crash/Unexpected shutdown etc) between the time the drawing was working and not working?
Message 5 of 8
No. I'm not positive when this happened but im 90% sure it was when I cleaned up the remaining lines and used UNION to combine the 3d solids. Still fairly new to 3d modeling so I'm trying to get the hang of it all
Message 6 of 8
And the ucs icon has been that color throughout
Message 7 of 8
nestly2
Thanks for the additional info.  I can't say I've seen anything quite like that before.  My guess is the Solids, or the drawing got corrupted somehow.
Here's what I see in your drawing.  A dimmed UCS icon, and some "ghost" lines when moving/scaling after SELECT > All
If you're on Subscription, you can submit a support request and it might help them fix whatever caused the problem.
Message 8 of 8
thank you so much for the help. Ill probably just resign it, luckily its not super complicated. thanks again!
Forma Design Contest
AutoCAD Beta
