When I plot drawing DWG to PDF the default file name shows the name of file and the name of layout.
AB_CAD
AB_CAD
When I plot drawing "DWG to PDF" the default file name shows the name of file and the name of layout. How can I change setting so it should not to take layout name when I plot. please see the attached image jpg.
vinodkl
Hi @AB_CAD
Try publishing instead of plot. Select a minimum of two layouts by holding the shift key and then right-click on the layout and select "publish selected layout". Now remove the layout which you don't need by clicking on "remove sheet" and then publish 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ennujozlagam
you can check it here and see if helps. thanks
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-To...
AB_CAD
Not solve, still prefix display file name & layout name
pendean
Community Legend
Community Legend
@AB_CAD There is nothing automatic to do what you want in the program. Either start using SSM and rename the tabs, or use PUBLISH to rename the output files and save lists, or customize with LISP then abandon all the core commands that do not do what you want.
How would you like to proceed? There are no other options really, you have to opt into another solution.
AB_CAD
if you have lisp please share with me. thanks
maratovich
Use this -Revers
You can specify any file name for saving.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
