What plot limit settings does SSM use when plotting to "PDF"?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Yah, I should know this but discovered I don't.
Normally, our company plots using named page setups.
That says exactly what the limits, scale, pc3, and so on are.
To publish, we use the publish command and set to "plotter named in page setup" and so on, it all works.
We can save a .dsd file for next publish and its all set up.
However, it takes a few more clicks than the SSM, right click, Publish, "Publish to PDF".
People familiar with SSM and publish know that is using the default acad pdf plot driver and NOT a pc3.
You can tweak the settings of merge and so on easily for that, but the question is where are the plot window, scale, and other settings coming from?
Is it the last used plot settings? (It must be IMO)
Is it the last current named page setup? (doubt it)
Is it some template I am not aware of?
Is it magic? (starting to believe...)
I wish we could designate a .dsd as the one to use to publish a set, and plot to that with 2 clicks like the SSM has now for "Plot to PDF".
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
