My model space drawing is in meters and in layout title block frame size is (1179x831mm)
What is my layout (paper space) scale?
I am confused with below tabs in properties panel as below
Annotation scale: 1:100
Standard scale: custom
Custom scale: 20
And at the bottom right "view port scale" is display 20.000
Please check the attached drawing and screen shot jpg.
what is the easy method to understand scale in layouts (paper space)
@AB_CAD ,
@AB_CAD wrote:My model space drawing is in meters
When working in Metric, use the acadiso.dwt template, instead of the Imperial.
Afterward, chose the proper paper size (Note: Layouts should always be 1:1).
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
review this thread to get a better understanding when you draw in meters but plot in mm and how you end up with 20 custom scale:
