MText is offset from insert point.
simon.pang
simon.pang
I am using AutoCAD 2024.  The MTEXT problem I have is that when I click a point and insert a MTEXT, it first appears at the correct location.  That is, at the center of the cross (0,0,0) as shown in the first picture below.  However, when I am done with the command, the text is offset.  Please see the second picture.  Please help.  Thanks. Running the command "MText"Running the command "MText"After completing the command.After completing the command.
Kent1Cooper
I have not seen that, but for decades have seen the opposite in plain Text with some AutoCAD .shx fonts.  For example, ROMANS.shx in left justification "starts" a little to the right of the insertion point.  It has always been that way -- why characters are defined off their start point has always been a mystery to me.  SIMPLEX.shx does not do the same, and otherwise I think is identical to ROMANS.  But for me, in Mtext, ROMANS.shx behaves as one would expect.
I doubt it will solve your problem, but I'm curious:  does using SIMPLEX.shx in the Text Style in place of ROMANS make any difference?  For me, it does not in Mtext the way it does in Text.
Kent Cooper, AIA
Valentin_CAD
@simon.pang ,
I can't replicate your issue.
Have you installed, reinstalled, or uninstalled Microsoft Office or other VBA enabled applications after installing AutoCAD?
Also, make sure your UCS and PLAN are set to World:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
simon.pang
Thanks Emilio.  Yes, I have VBA's in my Startup Suite.  Once I removed them all, MTEXT was working as expected.  I will follow your FAQ instructions for the solutions. Once again, thanks for pointing me in the right direction.  (Never thought of the VBA's are the culprit.)
