AutoCAD Forum
WHAT DIM SETTINGS MAKE THESE REAIUS DIFFERNT
4 REPLIES 4
nikm42Q9N
310 Views, 4 Replies
Attached shows two radius dimensions of the same thing. One is just a leader and the other is a leader line to center. im trying to figure out what settings make the one with just the leader and no line to center. Trying to apply to our company standard dimensions but cant figure what setting are needed. I can just copy and change the fudge the settings, but I would like to know how to do it from scratch. Thanks
john.vellek has embedded your image(s) for clarity
4 REPLIES 4
pendean
in reply to: nikm42Q9N
Post the actual DWG file please.
Kent1Cooper
Here's the text-direction distinction [in the DIMSTYLE Manager, Modify... dialog box]:
And here's the one that gets that line toward the center, though for me it only puts that in when the text is outside the curve, so I assume there's another setting I'm also not finding, to get that when the text is inside:
Kent Cooper, AIA
nikm42Q9N
in reply to: Kent1Cooper
Hi sorry about bad English. I am looking for the option with no center line. I just want the leader and the dimension at 90 degrees like the first example. We have many radius tickets to make and the center line just gets in the way
john.vellek
Hi @nikm42Q9N,
These are the settings I have:
John Vellek
AutoCAD Inside the Factory
