Weird small problem with Windows preview+ AutoCAD
Message 1 of 10
Hello guys,
There is a thing that is going on with the projects I'm working with. In Windows, on the side panel, it shows a nice and correct preview. But when I open it on AutoCAD, it shows a sheet being flipped/dissapeared.
Is there any way to solve this?
Note: The dwg file is exported fromout Revit.
Replies (9)
Message 2 of 10
S.Faris
What is the file size of your exported dwg file?
Refer to these :
Exporting from REVIT to DWG issue
Error exporting Revit to DWG file
SALMANUL FARIS
Message 3 of 10
Mostly less than 0.5 MB. Here a screenshot:
Message 4 of 10
S.Faris
i recommend you to post this issue in the Revit forum. The people might there will be able to identify the real issue.
SALMANUL FARIS
Message 5 of 10
Yes I'm going to do that if I can't find an answer here. It's mostly AutoCAD related, so I'll wait a bit more.
Message 7 of 10
RobDraw
Agreed, not an AutoCAD problem.
Rob
Message 8 of 10
Message 9 of 10
S.Faris
Posting on the Autodesk Revit forum is what I meant : Revit Architecture Forum
SALMANUL FARIS
Message 10 of 10
Same name, my bad. Adjusted it 🙂
