AutoCAD Forum
Weird CUI Issue
6 REPLIES 6
ko.bach276
409 Views, 6 Replies
Weird CUI Issue
I have a weird CUI issue, whenever I try to make any kind of change to my custom CUI(add new items or modify existing) all the toolbars will disapear and will not be accessible by any dropdowns or commands. When you go back into the CUI they still exist I'm just unable to turn them on. This is a shared CUI on our network.
6 REPLIES 6
After you created a toolbar make sure you have activated it in your workspace!
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
I type -toolbar > ALL > Show and before I modify the CUI they show up and after I modify the CUI they don't.
I can only repeat my question: after you activated all toolbars, have you saved your workspace?
And then a step by step: start command _CUI, create a new toolbar in the custom cui, save the modifications in the toolbar then modify your workspace and make sure to activate the new toolbar in that workspace, then close CUI.
- alfred -
Alfred NESWADBA
See attached for my "broken" cui.
-KoBach
Well, I loaded your CUIX as partial menu, created a new workspace, activated your toolbars, saved again the workspace and whatever I do now (even close AutoCAD and open it) I can see your toolbars.
So for me it looks like it's working.
What should I do now to make them disappearing?
- alfred -
Alfred NESWADBA
All I have to do is duplicate a command and it'll wipe them all out.
Forma Design Contest
