Weekly New Knowledge Network Articles | AutoCAD
matthew.d
Alumni Alumni
matthew.d
Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and/or updated for AutoCAD?
Subscribe to receive updates for new AutoCAD Knowledge Network articles.
For more updated solutions, check out the AutodeskHelp Blog!
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
January 2016
Weeks 1 and 2:
Missing drawing lines when importing CAD file into Revit
Mouse will not work in AutoCAD and Microsoft Office
Week 3:
Dimension information disappears when the Layout scale is changed in AutoCAD
Export to AutoCAD DWG from Inventor - dimension value is wrong
External reference (xref) management strategies in AutoCAD
How to differentiate Inventor DWG and AutoCAD DWG in Windows File Explorer
How to maximize the ribbon panels
Importing a Pro E file into Alias results in untrimmed surfaces
Install Error: AutoCAD 2016 is not found on this computer.
Linetype cannot be changed from the ribbon menu
Linetype scale greyed out in the Properties palette in AutoCAD
Unable to plot layouts correctly in AutoCAD 2016
Using formulas in multiline text objects
Using the Shift key in AutoCAD hangs the program for a moment
What is the difference in the assignment of the object properties ByLayer, ByBlock and ByObject in A...
Week 4:
An AutoCAD dwg imported in Revit results in a wide zoom extents
Password protection no longer available in AutoCAD drawings
Printer properties show Asian text when viewed through the English version of AutoCAD
Unable to view ArchT objects in AutoCAD
Where can I find a list of AutoCAD keyboard shortcuts?
Week 5:
Add-A-Plotter Wizard fails while adding a plotter in AutoCAD
Adding “Instantaneous Grade” data band properties to a Profile View
Can I exclude certain layouts from data extraction in AutoCAD?
Intermittent fatal error while working in AutoCAD 2015
Problem creating PDF in AutoCAD
Viewing Plot styles in AutoCAD for Mac brings up wrong folder
Matt DiMichele
matthew.d
Archive
December 2015
Week 1:
AutoCAD 2015 installation fails on system with .NET 4.6
How to add a CLASSICLAYER command to a Toolbar
How to list all attache external references (XREF) of a drawing
Inventor - Cannot Export AutoCAD DWG when using Raster views.
Polyline information after LIST command: Please use AREA command for self-intersecting polylines
Running AutoCAD you get a fatal error ‘System.Exception: Error Compiling Expression"
Sheet Set Manager shows up blank in AutoCAD
Week 2:
BIM 360 Glue Add-in for AutoCAD 2016 is not attaching model from another Glue Add-in version
Error: Could not attach signature. File may be read-only or in use.
Opening drawing but nothing is visible in the drawing
STLOUT cannot export model to negative coordinates from AutoCAD
The toolbar icons are white on light grey background if AutoCAD is set to light color scheme
Week 3:
Certain dimensions in the drawing appear to be locked or not editable
Command preview not shown when drawing an ellipse in AutoCAD
Dynamic block attribute value displays incorrectly when first inserted into a drawing in AutoCAD
Error: “This page cannot be displayed” when using XPS Viewer to open DWFx files created in AutoCAD
Incorrect display of derived sketch in an exported AutoCAD DWG when a view contains a Break
Raster image transparency is not considered in polygonal viewport in AutoCAD
SWEEP command doesn’t work on some geometry in AutoCAD
Unable to see AutoDesk Vehicle Tracking 2015 tab in AutoCAD 2014
When you start the program it lists “You have ## days to establish an internet connection”
Week 4:
Attributes in a block reference cannot be edited
Chinese font change to question mark
Double-clicking folder shortcut in the Select File window in Windows 10 crashes AutoCAD
Drawing files take a long time to open in AutoCAD
How to disable AutoCAD Hardware Acceleration during an installation
How to disable or change the color of the rubber band in AutoCAD
How to hide viewport frames
How to use user-defined parameters for parametric dimensions
Hyperlink syntax in AutoCAD
Matt DiMichele
