AutoCAD Forum
Weeding vertical elevation only
2 REPLIES 2
cgcok
177 Views, 2 Replies
I'd like to weed vertical values rather than complete vertices or PI. Is this possible? When weeding with grade factor only the vertices/PI are completely deleted even when horizontal weeding factors (Angle, Grade) are not used. I'm not sure why the WEEDFEATURES command works this way. Is there something I'm missing? Thanks
2 REPLIES 2
TheCADnoob
in reply to: cgcok
are you using vanilla AutoCAD or civil 3d? This is the AutoCAD forum.
That said... would flatten do what you need?
CADnoob
cgcok
in reply to: TheCADnoob
sorry I'm using civil 3d I will post there. I don't see a way delete my post. Thanks
Forma Design Contest
AutoCAD Beta
