Want to change all the existing dimensions to specific layer.
Manicbala
Manicbala
I need to change all the dimensions in my drawing to specific layer (Ex: DIMS).
Please advise any shortcuts/lisp to change at one time.
Bala
imadHabash
since we need more details ... but let's start with :
  • LAYISO command to isolate selected and different type of dimensions . LAYON to turn all layers back .
  • QSELECT command , and by preparing proper values .
  • SELECTSIMILAR command will also help .
  • also you can set a certain layer just for dimensions by DIMLAYER system variable . >> Click <<
Imad Habash
Manicbala
There are lots of dimensions with different layers in the drawing, I want to select all the dimensions and change it to specific layer. If any lisp for this issue will be helpful.
DIMlayer command not in Autocad 2015.
Bala
imadHabash
Ok ... then FILTER command may the better way .
 FILTER >> Select Filter: Dimension >> Add to List >> Apply ..... select the whole existing elements to filter out only the dimensions .
Imad Habash
neaton
Here is a quick script file that will do what you want. Change "0" to your layer name. There are 2 returns at the end to accept then close out the change command.
     (ssget "x" (list (cons 0 "DIM*")))
     change p  properties layer "0"
I also found this >>LISP routine<< that does the same thing.
Nancy
BeKirra
The code below may help straightforwardly while other offers here also work.
SD is the command you need to enter since your target dimension layer is "DIMS".
(defun c:SD (/ SelectDim)
(setq SelectDim (ssget "X" '((0 . "DIMENSION"))))
(command "._Chprop" SelectDim "" "Layer" "DIMS" "")
(princ)
); end of defun
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Manicbala
Thank you so much.
Bala
