AutoCAD Forum
AutoCAD and point Clouds
3 REPLIES 3
290 Views, 3 Replies
Hello
Does anyone know the limitation of point clouds into AutoCAD ... is there a maximum size of Cloud that can be loaded? is there a maximum number of points?
I have experience of freezing with Clouds loaded machine is a pretty good spec
HP 8200CMT
Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
16GB RAM
AMD Radeon HD 6570
3 REPLIES 3
john.vellek
Hi @Anonymous,
I am not aware of any limitations or maximums in working with Point Clouds.  Here is a link to the Help on this topic. It appears to be largely based on the resources available on your computer.
If you are having performance issues, try reducing the density a bit to see if it helps.
John Vellek
dgorsman
Which version of AutoCAD?
How are you loading the point clouds - native ReCap file?  Neutral-format PTS file?  CloudWorx or other third-party plug-in?
What else do you have in the model?
The native ReCap file reader does a good job of managing the point cloud (clipping boxes, for example), as does the Leica CloudWorx tools.  However, given the scale of operations normally used in AutoCAD projects loading in a super-large point cloud isn't productive.  While you're working on one end of a facility (or floor of a building, etc.) there's no benefit to having scans of *everything* available.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
in reply to: dgorsman
Hello
Thanks for the reply … I'll confirm with the tech about the how the clouds are loaded.
The Version of AutoCAD is 2018 and the cloud size is just over 5GB
AutoCAD Inside the Factory
