radial and complex lines on screen attached on drawing.
Those anybody could express me how can I rid off those strange lines over my drawing on the screen.
Many thanks,
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I am not positive what those lines are.  Try turning off Line Smoothing in GraphicsConfig to see if they go away. If not then try toggling Hardware Acceleration.
You are welcome to attach the file to a post an I can try to duplicate this behavior on my side in order to make further suggestions.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Dear John Vellek,
Please accept my cordial thanks for your very prompt response and my apologies for not being able to answer you in due time.
Your suggestion of "turning off Line Smoothing in GraphicsConfig" worked wonderfully.
With regards,
Şükran Şahin
