Objects move out of place when plotting to pdf
I have a series of layouts where a viewbase is over a viewport in order to get a 3d model into paperspace with both lineweight and color (I did it that way because the color option in viewbase gave me a pixeled image wich I couldn't get to work properly, even bu adjusting de DPI).
Things were working just fine the las time I plotted them, but today it appears the Objects move out of place, and it is deiving me nuts because IT SHOULDN'T HAPPEN! In the layout they arr aligned and in the pdf they are moved.
I need help with this garbage, honestly I don't know what to do anymore.
john.vellek
HI @Anonymous,
Is it possible to share your file so i can take a look?  Which PDF driver are you using?  Do you have a pagesetup applied?
What version of AutoCAD are you using?
John Vellek
john.vellek
HI @Anonymous,
I have not seen you come back to this thread and I hope that you have resolved your issue. If not, please provide some additional information so I  can try to assist you.
John Vellek
