Anyone else having issues with *vpfreeze layers showing up your viewports in AutoCAD 2024?
I didn't notice it after I installed 2024, but just a few days ago (maybe 4-5 days after installing) I noticed the layers I have set as frozen in a viewport are still visible in the viewport.
The layer isn't plotting, but it is visible. Before 2024, the layer would always freeze when frozen.
VISRETAIN=1. Is there another setting that may be affecting this in 2024?
Solved by cadffm. Go to Solution.
Sure. 100% certain, @pendean. I actually picked ON the object on the layer I wanted to freeze and selected the correct layer to VPFREEZE. None of the objects are xref'd in, nor are they in blocks. However, they are 3D objects in MS. That layer, which does still show up in the VP is not plotting, which is why I'm not too concerned. Also, I can FREEZE that layer, and it disappears from all VP. It's just the VPFREEZE that doesn't turn the layer off in the VP. To take it a step further, I also shut down AutoCAD and rebooted my computer before I posted this. Pretty much exhausted all my normal avenues 1st. And yeah, I only mentioned VISRETAIN because I had seen other posts that ask what their VISRETAIN was set to. 😉
EDIT: I tried this in another drawing (one provided by someone outside my company) without issue. The VPFREEZE works as it should. Which is what leads me to think it may be a drawing level setting, or possibly even a glitch.
So, if you VP Freezed the layer in the right viewport: Share your sample DWG and tell us the name of your Layer (mark the object and share your Screenshot)
Sebastian
Sebastian
@pendean, are any of those projects in 3D with your Viewport set to "Shaded (fast)" or "Shaded with Edges (fast)"? When I switched my Viewport to "2D Wireframe", the VPFREEZE works as expected.
In this drawing is a single 3D object in MS with a Viewport set to "Shaded (fast)" and the HC-3D-PIPING Layer set to frozen in that VP. When I saved the DWG, the layer was still visible in my VP. If I switch to "2D Wireframe" the object disappears from the VP and if I switch back to "Shaded (fast)" it comes back on.
EDIT: I verified this issue by opening that same drawing (as saved) in AutoCAD 2023 and the layer is not seen in the VP upon opening the file. I was able to (UN)VPFREEZE and it works as expected, even in "Shaded (fast)".
Just bumping to the top to see if anyone else may have some info. Thanks.
I confirm it also in 2024.0.1
time to send this to AutoDESK ! We (other users) can't help.
Both "shaded" visual styles
Sebastian
Sebastian
Disable your FAST SHADE MODE (Command Graphicsconfig),
now, it works as expected, right?
So the problem appears by hardwareacceleration on, visual style - shade and enabled fast shade mode.
Sebastian
Sebastian
DING DING DING!!! Folks, we have a winnah!! Thanks for that, Sebastian.
Command: FASTSHADEDMODE = Off (or 0) also works.
