AutoCAD Forum
Visual Styles in 2024 not working
1 REPLY 1
hdelasa8MB93
179 Views, 1 Reply
I just installed AutoCAD 2024 and for some reason when I try to apply the different Visual styles, to my model  they are not working.  Also after this,  the area in the viewport screen turns black and the objects disappear from the screen. Do you know why this is happening? Thank you.
1 REPLY 1
pendean
in reply to: hdelasa8MB93
@hdelasa8MB93 wrote:
I just installed AutoCAD 2024 and for some reason when I try to apply the different Visual styles, to my model  they are not working....
Have you installed the 2024.1.5 Update yet? ABOUT command in your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2024.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
HTH
Forma Design Contest
