AutoCAD Forum
Visual Style Changing
3 REPLIES 3
JPaullXKUFL
95 Views, 3 Replies
I am working on a drawing and recently notices that things looked different. I realized my Visual Style had changed from 2D Wireframe to Wireframe. An older version of the same drawing is in 2D Wireframe and I never experienced any of this but the current file always reverts to Wireframe.
When I try to change it back to 2D Wireframe and then REGEN the drawing, it goes back to Wireframe.
Not sure how this happened or how to stop it from reverting to Wireframe.
Any help is much appreciated, thanks!
3 REPLIES 3
jayhar
in reply to: JPaullXKUFL
First> Run the AUDIT command >
AUDIT Fix any detected errors: Yes
Second > Purge unused elements with the PURGE command >PURGE [Enter] PURGEALL [Enter]
After cleaning the drawing, set the visual style again and test if it holds after REGEN
Third > Some system variables may be set to revert the visual style
VISUALSTYLE Variable: Confirm it’s set to 2D Wireframe.
REGENMODE Variable:Type REGENMODE and ensure it’s set to 1
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
paullimapa
Could you share this dwg here to see if community can replicate?
Paul Li
IT Specialist
@The Office
JPaullXKUFL
in reply to: jayhar
Just completed all the steps and it looks like it worked.
Thank you!
AutoCAD Inside the Factory
