I have read several forum posts and did not seem to find the answer to my problem. I am editing a block, adding visibility states. Everything is fine but then I received an email so I clicked over to my email screen and the visibility states menu box disappeared. When I returned to AutoCAD all I hear is the "bell chime" sound. I cannot click on anything in AutoCAD. It is like it is locked up or something. The screen appears fine but the title bar is gray, so I know that means I am not in that window. I tried using Alt+Tab to select that window, it failed also. Right clicking the app icon then selecting close window does nothing either. I have to use the Task Manager to close the app. What's weird is that the Task Manager does not show "Not Responding". I just upgraded to 2022 and this is the first error I have found in 2022.
Solved by pendean. Go to Solution.
I think I had problems with email notifications too, but don't ask me how to prove it.
I have 4 monitors and 1 laptop. I had tried closing all other applications to find the menu but no luck. I even tried hovering over the AutoCAD app icon to see if it displayed the location of the menu but again nothing. As a test I opened block editor again, clicked visibility states, moved it to another screen, then click a different screen. The menu disappeared completely. I think it is a glitch.
Start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
I have three monitors and a laptop for what it's worth. The problem hasn't croppped up lately.
@Anonymous, how are your program updates?
Did you ever get this resolved? This just started on my machine. I am up to date.
