Virtual memory low on AutoCAD 2018
I am running AutoCAD 2018 and after opening a few drawings I get a windows message that the virtual memory is low and windows will be shutting down some programs.  Windows then shut down AutoCAD and I loose the drawing that I have open.  I have checked with the computer tec and he says its a AutoCAD issue, not a hardware issue.  Can you help please?
pendean
Community Legend
Community Legend
Are you running 32bit Windows? 32bit AutoCAD2018?
Have you already tried to increase the size of the virtual memory in Windows?
Do you only have 4Gig RAM or less?
How many background apps are you running?
What size DWG files are you opening?
If you turn off your anti-virus software, as a test, does the problem go away?
I am running 64 bit Windows and 64 bit AutoCAD 2018.
I have not messed with increasing the virtual memory, but the system is set at 1846 MB recommended and 21999 MB allocated.
I have 8 GB of RAM.
I am running 84 apps in the background
DWG size is around 4200 KB
Anti-virus software on or off doesn't seem affect it.
pendean
Community Legend
Community Legend
Same specs as my PC for the most part: not seeing this issue. is the 2018 hotifx installed? I have it.
it's going to look ugly but run Windows is Diagnostic Mode then start AutoCAD and try to replicate the problem https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
if not, visit with your IT, something else is choking AutoCAD 2018.
