viewsection
viewsection
jan.sirka83
viewsection
jan.sirka83
Hello there.
I am using "layout section" quite often, but it just does not work anymore! It happened while I was working on the file and I am not aware I have changed some settings...
Instead of doing a section it just produces a view and even with not the same properties as the parent view (invisible hidden lines...)
Is somebody willing to review my file tell my, what am I doing wrong?
I will be really glad to hear any suggestions, comments, ideas, how to fix it, or if it is necessary, how to produce my plans different way.
Thanks a lot!
win7 64 bit
autocad 2020
dbroad
Worked for me when I copy/pasted your actual 3d geometry to another file.  There's so much annotative and non-solid projections in your model space that it interferes with using the model documentation feature.
Architect, Registered NC, VA, SC, & GA.
jan.sirka83
Thanks a lot!
Was not thinking that could be the issue.
copy paste into a new document was working in my case too.
