Viewports cannot be plotted
I am having an issue with a drawing, where in the paperspace I can see the contents of the viewport, but when trying to plot it all the items under the viewport are vanished. I have checked the basics, such as Audit & Purge command already implemented, and the layers required are set to plot option. See attached the file.
Accepted solutions (3)
john.p.addy
The layers might be on a no plot.
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
imadHabash
your problem occurred because your VP layer and the xref itself on unprinted layer.change it to another plotted one or modify it .
Imad Habash
john.vellek
Hi @Anonymous,
Both suggestions in this thread are correct.  You have inserted your Xref on the Viewports1 layer which is set to non-plot.  To correct this, click on the Xref and then place it on a layer specific for the Xref or on layer 0.
John Vellek
You are right. Thanks for the quick reply!
