Good morning all.
Working with a couple of drawings this morning and when I do a Zoom All in Drawing1 paper space viewport, it will zoom to my object in model space.
But when I do a Zoom All in Drawing2 paper space viewport, the same object is off in space.
The viewports aren't locked in either drawing, and I don't recall a zoom setting that would keep the object in Drawing2 from maximizing.
Thoughts?
"But when I do a Zoom All in Drawing2 paper space viewport, the same object is off in space"
Isn't it the same when zoom-all in MODEL tab?
No?
Please test it with a new viewport in another (new) Layout.
Yes, the same in model tab.
It is not the only object by chance, search for other object (miles away from it).
OR it is a view setting issue.
Share a screenshot of command _VIEW dialog, or better and if possible , share your drawing file.
Sebastian
When I do a zoom all in model space, it zooms correctly.
No?
If I put in a new viewport, the zoom all works correctly.
I looked at _VIEW, but didn't see anything abnormal.
Sorry, I'll have to add more details later.
@acclarkJR2TJ wrote:...Please test it with a new viewport in another (new) Layout.
If I put in a new viewport, the zoom all works correctly....
You found your fix: replacing the offending viewport it is. Your "drawing2" is corrupt OR there is something else in there for the "...the same object is off in space..." effect to take place.
You checked the the _VIEW dialog while inside the problem-viewport?
and the camera is set to 0,0,0 from 0,0,1 ?
Do it, all files (.dwg), screenshots, are welcome.
Sebastian
