Viewport size changing issue
w64bit
Message 1 of 11
w64bit
When modify the dimensions for a viewport using properties or quick properties windows:
- if you modify the width, the viewport scale is preserved (all OK)
- if you modify the height, the content is fitted taking into account the new height and the scale is changed (not OK AT ALL)
Can this be fixed?
Replies (10)
Message 2 of 11
Ed__Jobe
If you want to report a bug, you can do it here.
Ed
How to post your code.
Message 3 of 11
w64bit
Reported many times over the years.
No result.
Message 4 of 11
RobDraw
Have you tried locking the viewport before changing the size? It's a good idea to lock your viewports once the scale is set and is a part of any decent drafting standard manual.
Rob
Message 5 of 11
w64bit
Tried.
The same.
Message 6 of 11
RobDraw
That's not good at all.
Rob
Message 7 of 11
ChrisPreece
Hi @w64bit,
That is an interesting discovery for sure. I'll bring it to the attention of my team and see if anyone knows a reason for this to be the case. In the meantime, there are some simple workarounds available: use the corner grips on the viewport to modify height/width, or reset the scale of your viewport after modifying the height in the properties panel.
If this post answers your question or solves your issue, please click Accept as Solution so others in the community can find it easily.
Chris Preece
Technical Support Specialist
Message 8 of 11
w64bit
2024. The problem is still here.
Message 9 of 11
RobDraw
Some people say that the definition of insanity is doing exactly the same thing and expecting different results.
Do you need to be shown how to avoid this?
Rob
Message 10 of 11
w64bit
Please read post 7.
Message 11 of 11
RobDraw
And?....
I see that they suggest avoiding it.
Rob
