viewport scale problem
Message 1 of 11
Hi everyone. Does anybody knows why i cant write 20 in the viewport scale control tab? i cant put 15,16,17 etc. but not 20!!! i have to write 20.0!!!
Replies (10)
Message 2 of 11
imadHabash
would you please show us a screenshot for the viewport scale control tab ? also yo may need to unlock your viewport ( maybe ) .
Imad Habash
Message 3 of 11
The VP is unlocked...
Message 4 of 11
imadHabash
i see from your attached that you can write 20 !! isn't ? if you start a new CAD drawing did your issue still exist ? if yes would you please share with us your CAD drawing sample as AutoCAD 2013 format type ?
Imad Habash
Message 5 of 11
i cant write 20!!!! i can write 20.0(......17, 18, 19, 20.0). this is really weird. its not a big deal but i cant understand why! for years i just wrote 20. from today i have to write 20.0
Message 6 of 11
Alfred.NESWADBA
I can write 20, in the toolbar as well as in the property window ... and after <ENTER> all is well, view is updated.
What do you mean by "I can't write 20" ... do the letters not appear in the field or what is the issue?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 7 of 11
If i write 20 i loose my scale!(it zooms out). i must type 20.0 (twenty point zero) to keep the correct scale
Message 8 of 11
Alfred.NESWADBA
is that drawing dependent?
Can you please create a video from that behavior (e.g. using >>>Autodesk Screencast<<<) + show a screenshot from command _ABOUT so we can see your version of AutoCAD?
- alfred -
Alfred NESWADBA
Message 9 of 11
I found the guilty. look at the diferrence between 20 and 20.0. i dont know how that happened. Now how can i delete it. it wont delete and it doesnt let me edit.
Message 10 of 11
Alfred.NESWADBA
good catch!
When you can't delete it then this scale is in use, either by a default setting, or by a viewport or by any annotative objects. If you can't delete it sometimes it's a help to rename it 😉
- alfred -
Alfred NESWADBA
Message 11 of 11
leave it i found it! double click and change name(close cad and reopen it)!!!! thanks guys!
