viewing proxy entities
I am working with regular Autocad 2011, is there any way I can view Proxy Entities created in Civil or Architect?
imadHabash
you can found and follow any proxy entity by QSELECT command line ( see attached).
fill the info on proper way and all entities will selected .
after you find some proxies objects you can make sure by see all proporties from (Ctrl+1) .
Good Luck...
Imad Habash
Alfred.NESWADBA
why opening a new thread for the same question?
>>>this thread<<< was used to discuss it and it was already marked as solved.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
As @Alfred.NESWADBA indicated, the solution is to use -EXPORTTOAUTOCAD.
Object Enablers for 2011 product can be found here.
AutoCAD Civil 3D 2017 is also not backward compatible. I hope this helps.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
