I am working with regular Autocad 2011, is there any way I can view Proxy Entities created in Civil or Architect?
Solved by john.vellek. Go to Solution.
Solved by imadHabash. Go to Solution.
you can found and follow any proxy entity by QSELECT command line ( see attached).
fill the info on proper way and all entities will selected .
after you find some proxies objects you can make sure by see all proporties from (Ctrl+1) .
Good Luck...
Imad Habash
why opening a new thread for the same question?
>>>this thread<<< was used to discuss it and it was already marked as solved.
- alfred -
Hi @Anonymous,
As @Alfred.NESWADBA indicated, the solution is to use -EXPORTTOAUTOCAD.
Object Enablers for 2011 product can be found here.
AutoCAD Civil 3D 2017 is also not backward compatible. I hope this helps.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
