AutoCAD Forum
Viewbase not generating isometric projections
3 REPLIES 3
dmillard
482 Views, 3 Replies
So I am using viewbase to create the views in my drawing file. And it is creating the normal (Left, Right, Front, Back, Bottom, Top) views just fine. However any time I try to make an iso view it will sometimes show the preview (when in the VIEWPROJ command) but not always, and then when you chose what direction you want, it will think like it is creating the view but it will never create it. It always makes a dot about a 100ft away from my other objects, that has no geometry linked to it. Any ideas on how to fix this?
3 REPLIES 3
beyoungjr
in reply to: dmillard
Can you post the drawing?  Do you recall if you have altered the settings for your view styles (Hidden, Shaded, Shaded with edges, Realistic, Conceptual)?
Any of these alterations should travel with the file so I can have a look.
Cheers
Blaine Young
Senior Engineering Technician, US Army
john.vellek
Hi @dmillard,
Which version of AutoCAD are you using? Is it fully up-to-date?
I too would like to see the drawing file to see if I can make it behave.
You might try scaling the contents of your model by 1.0001 and then recreate the views to see if they appear properly.
John Vellek
john.vellek
Hi @dmillard,
Did you check your AutoCAD for updates?  I am hoping that will correct the issue you are seeing with the Viewbase views.  You are welcome to attach a sample file to a post so I can take a look.
John Vellek
AutoCAD Inside the Factory
