VIEWBASE issues with Inventor
ali_jahed
ali_jahed
Hi All,
Has anyone worked with VIEWBASE intensively in conjunction to Inventor files?
The objective is to create a full 3D model in Inventor and make all ipt, iam and ipn files available to AutoCAD user to create technical manuals and etc. So whenever the parent file got updated all the associative files gets updated automatically.
I started testing the command; however, I faced to few issues.
Please see below my topic (which I raised in Inventor Forum by mistake) and leave your comments here.
https://forums.autodesk.com/t5/inventor-forum/viewbase-command-in-autocad-doesn-t-work-with-ipn-file...
It is a great feature if works...
Cheers
pendean
Community Legend
Community Legend
@ali_jahed You're not using AutoCADMECHANICAL? or you are in the wrong forum if you are, can you confirm?
ali_jahed
I am not using AutoCAD Mechanical.
