Hello there,
I am Ashutosh and using autocad-2012.I am unable to open viewbase command in model space.I tried tips from forum about drawing a box in the model space and then trying.But this didn't help.Every time I try to use the command viewbase,it only goes on to show "inventor server failed to load".Can anyone solve my problem?
Ashutosh
2012 was the first year for VIEWBASE, and it does not work from Modelspace. Select a Layout tab (preferably one without any existing viewports) and launch VIEWBASE from there.
Make sure you have all updates and Service Packs for AutoCAD2012 installed
ViewBASE - Inventor server failed to load
also make sure MODELDOC.cuix is loaded (CUILOAD command)
