AutoCAD Forum
Viewbase command
7 REPLIES 7
Message 1 of 8
699 Views, 7 Replies
Viewbase command
Hello there,
I am Ashutosh and using autocad-2012.I am unable to open viewbase command in model space.I tried tips from forum about drawing a box in the model space and then trying.But this didn't help.Every time I try to use the command viewbase,it only goes on to show "inventor server failed to load".Can anyone solve my problem?
Ashutosh
7 REPLIES 7
Message 3 of 8
nestly2
2012 was the first year for VIEWBASE, and it does not work from Modelspace.  Select a Layout tab (preferably one without any existing viewports) and launch VIEWBASE from there.
Message 4 of 8
in reply to: nestly2
Hello Sir,
Thanks for your time.But it doesn't work that way either.I also tried drawing a box inside the layout space and use viewbase command.It didn't work.It keeps saying "Inventor server failed to load."
Message 5 of 8
nestly2
Make sure you have all updates and Service Packs for AutoCAD2012 installed
 ViewBASE - Inventor server failed to load
also make sure MODELDOC.cuix is loaded  (CUILOAD command)
Message 6 of 8
Tried everything,from updating to installing hotfixes and drawing boxes in
layout space and model space whatever.Still not able to fix the problem.It
as it is "inventor server failed to load".Anyway very thanks for your time.
Ashutosh
Message 7 of 8
nestly2
Do you have the Drawing Views panel on the Annotate tab?
Message 8 of 8
I tried the tips as given above.My annotate panel does show the base view command but doesn't work.It comes back with the same notion,"Inventor server failed to load".
Forma Design Contest
