- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having an issue getting the VIEWBASE command to work properly when laying out a 3D model in paper space. I've attached a couple pictures that show the steps I'm taking, and a DWG of the file.
Picture Explanations:
(1) After going to paper space, clicking the layout tab, selecting the drop down arrow under base, and choosing "from model space" I am taken to this screen. It shows that only some of the objects in my model are selected to show up in paper space, this is the problem I'm trying to fix.
(2) After I draw a selection window around the entire model, (I've also tried pressing "e" for Entire model), and release the mouse, the command line shows "2831 were filtered out, 91 groups, 1668 total", and the selected objects remain the same.
What is causing this command to filter out certain objects from my model?? I generally do my paper space layouts with manual viewports, but I recently watched a tutorial showcasing this command and wanted to implement it.
Thanks for any help!
Jarrod K.
