- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Ok, back again - I have my views set up (basically I rotate my drawing 90, 180, 270 and back to 0). When I choose my named view, the drawing turns nicely - but the UCS does not. So when I am working on the new view the horizontal and vertical construction lines are backwards - this is quite frustrating.
I used to just change the UCS with the good old manual 'Z' pick, which worked perfectly, but I am trying to simplify my life (a tiny bit) and just pick the named view - can I set them up so that the UCS changes with my named views?
FYI, I have tried the USCFOLLOW command, neither 0 or 1 fix this problem.
