View question
View question
不适用
722 次查看
8 条回复
1 条消息(共 9 条)
View question
不适用
How can I get back the selection box for view types, like Wire Frame and Shades of Grey?
0 个赞
723 次查看
8 条回复
回复 (8)
2 条消息(共 9 条)
Alfred.NESWADBA
已接受的解答
You don't need to get anything back, it's present in modelspace in the uppoer left corner (or you start command _VISUALSTYLES)
Click onto the "2D Wireframe" text ==> that gives you the visual styles listed which are defined in your drawing.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
3 条消息(共 9 条)
不适用
It was at the top in the center.
0 个赞
4 条消息(共 9 条)
Alfred.NESWADBA
已接受的解答
Did you even try my suggestion? I'm sure my suggestion is the faster one ... but well you can change your workspace to "3D Modelling" then go to ribbon "Visualize" to find that (3 clicks more 😉 )
- alfred -
Alfred NESWADBA
5 条消息(共 9 条)
不适用
That worked.
0 个赞
6 条消息(共 9 条)
不适用
已接受的解答
I just download AutoCAD LT 2017 today and don't see the high DPI display problem fixed.  I am running 200% scale factor.  Is this only fixed for the core AutoCAD 2017 and not for the AutoCAD LT version ? Will there be a AutoCAD 2017 LT fix anytime soon?
0 个赞
7 条消息(共 9 条)
不适用
8 条消息(共 9 条)
GrantsPirate
Open the About window and see the product version number.  Should be 2017.1.1.  If not then download the 2017.1.1 update and install.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
9 条消息(共 9 条)
不适用
已接受的解答
Downloaded both the service pack and the update and all is better (not perfect).  Autodesk still has some work to do but at least things are usable now.
Thanks for the info.
