VBA support not activated
Message 1 of 8
I download the VBA module to activate VBA support in AutoCAD 2019, and acvba.arx appears loaded in the Application loader screen. However, when I click on VBA Editor or Run VBA Macro, I always get an error message telling me the VBA support module has not been installed.
What did I miss?
Replies (7)
Message 2 of 8
jayhar
Download the Microsoft Visual Basic for Applications Module (VBA) click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 3 of 8
Hi Jayhar,
Thanks, but that's the whole problem: I already downloaded and installed that module, and AutoCAD still claims it's not installed, though it shows the application is loaded...
Message 4 of 8
Erense
I've seen this behaviour more than once.
Close all AutoCAD, Uninstall VBA and re-install
Make sure you are installing with sufficient rights. (admin/poweruser)
See if that works for you.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Message 5 of 8
jayhar
I understand you already install, this is updated. some of links i found in AKN. search here
1. VBA in AutoCAD click here
2. Serious Error: VBA failed to initialize properly click here
3. AppActivate Event (ActiveX) click here
4. Reinstall AutoCAD 2019
5. contact support click here feedback
Message 6 of 8
Thanks again, but I already tried all that. Uninstalling then reinstalling all AutoCAD, or just the VBA module was even the first thing I tried. I wanted to know if I had missed anything before contacting support, but apparently, it's the only choice I have left... I'll let you know how it went.
Message 7 of 8
Ed__Jobe
@Anonymous Did you install vba by clicking on setup.exe and not the msi. I have seen this when you use the msi to install it.
Ed
How to post your code.
Message 8 of 8
Autodesk support found that what was wrong with my install was wrong/corrupted temp files. They got me delete all install files and temp files, uninstall the VBA Enabler, then download/reinstall it again, and this time it worked.
Thanks all for your help!
