- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am drawing steam locomotive cabside numberplates and smokebox numberplates at full size which I will reduce to 1:76 to finally produce etched brass numberplates for my 'OO' gauge model locomotives. However, the font I am using for the cabside numbers is Old Street Sign and the font for the smokebox numbers is Gill Sans Semi-Bold as used by the Great Western Railway and British Railways. I want both sets of numberplates on the same drawing as I will be creating a laser print which will be ironed onto thin brass sheet to allow etching. But I do not seem to be able to use more than one font on the same drawing without the first used font changing to the second selected font. The main issue, I believe, is that the fonts are part of the drawings and not dimension annotations.
Is there a way of using two fonts in this way on the same drawing?
Thank you.
