- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to use the sum of a data extraction table in, for example in a field or text?
I created a block, containing the width and heigth of a wall finishing. Using data extraction I create a table with these width and height values, insert an extra column multiplying width and height to an area and add the footer with the sum of this multiplication. Now I want to use this sum in a field, but in the field properties I can't find this sum. Is it somehow possible to read this sum?
