Using system variable to xref path
m_simonettoBLR3F
Observer Observer
m_simonettoBLR3F
Observer
Observer
Hi all,
I've a problem with xref in AutoCAD. We basically have the main .dwg file on our server and the xref files in a shared OneDrive folder. Every time someone opens it AutoCAD doesn't find the reference because it search in C:\Users\User\etc even if the path is set to relative. It's possible to use a system variable inside the path to give make AutoCAD automatically fill the user part of the path so that the error is not present anymore?
I've tried with %USERPROFILE% etc but AutoCAD complain that the path isn't correct.
Any chance to solve it?
Valentin_CAD
@m_simonettoBLR3F ,
@m_simonettoBLR3F wrote:
... xref files in a shared OneDrive folder
... AutoCAD doesn't find the reference
... even if the path is set to relative.
Seems you have tried the suggestion from these links, but read the variables mentioned within:
Another suggestion would be the ones mentioned here:
Related topic:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
paullimapa
You can use projectname system variable to setup different paths per user.
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-9C5FB777-337C-433A-9562-F395BF77186D
As long as the dwg has the projectname set, then each user under AutoCAD Options > Files > Project Files Search Path can be set with a unique folder structure per that user.
So for example, using your company name as project name in each dwg set projectname to CompanyNameFolder. Then each user under Project Files Search Path would setup their own path for CompanyNameFolder like: C:\Users\Paul\AppData\Roaming\AutoDWG
Now as each user opens the drawing, their Options setup will search in whatever folder that's been specified based on projectname.
You can also read another example on this implementation here:
https://forums.autodesk.com/t5/autocad-forum/understanding-projectname/m-p/7042960#M876586
Paul Li
IT Specialist
@The Office
m_simonettoBLR3F
Observer
Observer
Thanks a lot, works very well!
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
