- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I've a problem with xref in AutoCAD. We basically have the main .dwg file on our server and the xref files in a shared OneDrive folder. Every time someone opens it AutoCAD doesn't find the reference because it search in C:\Users\User\etc even if the path is set to relative. It's possible to use a system variable inside the path to give make AutoCAD automatically fill the user part of the path so that the error is not present anymore?
I've tried with %USERPROFILE% etc but AutoCAD complain that the path isn't correct.
Any chance to solve it?
