AutoCAD Forum
Requested for change code in lisp
5 REPLIES 5
paliwal222
374 Views, 5 Replies
Dear all
a humble request for change code in lisp file
want to edit dimension in command bar by multiple selection
find a code in forum but it select one dimension at a time
i want multiple selection and edit one by one continuously
if it possible kindly provide the code please
5 REPLIES 5
paliwal222
in reply to: paliwal222
Solved by
Sir Kent1Cooper Thanks
(vl-load-com)
(defun c:dedit (/ seldim n dim cobj ns)
(prompt "\nTo override Dimension object(s) text content,")
(if (setq seldim (ssget ":L" '((0 . "DIMENSION"))))
(repeat (setq n (sslength seldim))
(setq
dim (ssname seldim (setq n (1- n)))
cobj (vlax-ename->vla-object dim)
); setq
(redraw dim 3); highlight
(setq ns (getstring "\nNew text content: "))
(vlax-put-property cobj 'TextOverride ns)
); repeat
); if
(princ)
paliwal222
problem already solved by Sir Kent1Cooper
(vl-load-com)
(setq
); setq
); repeat
); if
(princ)
paullimapa
give this a try:
; cc select & edit dimension string
; OP:
; https://forums.autodesk.com/t5/autocad-forum/requested-for-change-code-in-lisp/m-p/12304443#M1117115
(defun c:cc ( / seldim cobj ns)
 (vl-load-com)
 (princ"\nPick Dimension ")
 (if (setq seldim (ssget '((0 . "DIMENSION"))))
  (foreach b (mapcar 'cadr (ssnamex seldim))  ; create list of all entities from selection set & cycle through
   (if (= 'ename (type b)) ; confirm is entity
     (progn
      (redraw b 3)
      (setq cobj (vlax-ename->vla-object b))
      (setq ns (getstring "\nNew Dimension ? : "))
      (redraw b 4)
(princ)
Paul Li
IT Specialist
@The Office
paliwal222
in reply to: paullimapa
Dear Sir paullimapa
thanks very much
it's work correctly, it is more correct then above given code. i can copy and paste value from excel
above code is some error its select reverse but your code is more correct i can select dimension by fencing and its edit by sequence.
Thanks very much again from heart
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
